Howdy everyone...been lurking a while...
Newb here,
So I am posting for my parents, the pround owners of a 93 LC since new. I am looking for recommendations on a shop worthy of working on the White Whale in Washington. While this car has had the regular oil/belt/brake changes, and my father had some other PM work done a few years ago, it appears that this beast needs some attention. It has well over 155k on it (as the ODO stopped working there in '00) and until July of last year my mother drove it everyday, over 20K a year.
Basically I think the thing needs a major overhaul. Worried about the headgasket,
:whoops: fluid is going away...however there is no milkshake in the oil, but from some of my reading here, that isn't as good of an indicator as with other engines...
In addition, my father is convinced that the engine is burning oil but I only see a little smoke on startup. Any other ways of determining this?
My mother is so in love with the vehicle that she is scared that if she takes it somewhere that they will do more harm than good (this has happened a couple of times with other vehicles) and on a previous occasion when we took this vehicle in they tried to tell us the rear brake calipers were shot and needed replacing...
They are actually willing to spend money on getting it fixed (which is great) but I don't have the time to do it...and my father says that his wrenching days are over :) So I need someplace that knows this engine, so that my mother will feel safe leaving her "baby" there...
My mother is so in love with the vehicle that she is scared that if she takes it somewhere that they will do more harm than good ...
That is indeed a valid concern.
Why not start with a cylinder leakdown test and an oil analysis?
That would give you pretty darn comprehensive information about the condition of the motor and any trouble areas.
Curtis
Cary, you don't mention why you think something is wrong other than age and some fluid loss. Is the truck running poorly or behaving funny? If not, then keep up with PM and drive it until something surfaces. Don't make the mistake of assuming that, because the truck is old, it needs major work. LCs run forever.
LCs run forever.
No matter how many times I hear someone say this, it still gives me a warm-n-fuzzy feeling down in the cockles of my heart.:D
Corsair - thanks for the links to the local pages... I have asked over there as well...
Rob - The coolant loss is fairly heavy...but not seeing puddles or the milkshake in the oil...So it is leaking from the block somewhere...just can't find it... On top of that it has a very strange hesitation from about 1900-2400 rpm... If you are in that range the truck just doesn't want to accelerate unless you mash on the gas (sending the RPMs climbing)...
But yes...my mom is of the mind that if isn't broken don't fix it...
I am worried that the Headgasket leak may lead to some other problem... plus if the Head is off might as well change out / clean injectors etc.
I tend to prefer the fix it before it breaks method when it comes to routine maintenance, but not for a head job or an overhaul.
I agree, coolant loss requires prompt attention. Even if it isn't a sign of bigger problems, it can cause them. You can however lose an amazing amount of coolant without leaving puddles, so check it out before assuming that its going inside the engine. You may not find anything unless its under pressure. Check it at running temp. or use a pressure tester.
Other things to note, does the hesitation occur when its cold, hot or both? If coolant is getting in the cylinders, it will begin to run rough when it hits running temp. Check the plugs, if you are getting water in a cylinder, one or more plugs will be cleaner than the others. Get it up to running temp, shut it off and restart it 20 to 30 minutes later. If it doesn't turn over or blows a cloud of steam, you have a problem. :whoops: :crybaby::crybaby:
Head gasket leaks usually become obvious before long, the biggest consequense is usually the cost of towing.
A quick test for the head gasket is the bubble test.
https://forum.ih8mud.com/showthread.php?t=39455&highlight=bubble+test
Another source of leaks is the PHH, pesky heater hose. I was losing a small amount of coolant and passed a presure test. Replacing the PHH solved my coolant loss problem. The PHH is a common problem. Attached is a picture of my before replacement. Search for PHH and you will find lots of info
Hope this helps
Start cheap. Plugs, wires, air filter, PCV, cap, rotor and coolant flush, replace the PHH while the system is drained for the coolant flush. Your talking about 1 days work and under $250 if you do it all yourself. Then you can get a better idea whats going on with the truck before you take it to somebody to have it diagnosed. You may save your parents a lot of money and prevent the more harm than good worry from being realized.
If you do a search here on Mud you will find that there are detailed walk throughs for each item I have suggested.
Good Luck.
C'mon guys: He needs to definitively determine whether or not the headgasket's blown. First. Period.
Anyone NOT agree with this???
Generally, I prefer to start cheap and go from there. The bubble test is free and quick. Someone mentioned a Blackstone Oil Analysis, cost $22.00. Then there is visual inspection looking for pink residue where from under the head, mostly in the rear of the enging. I think this is an excellent starting point.
You can also take it somewhere and have a pressure test, hydrocarbon test etc.
