- Thread starter
- #21
How about a Blackstone oil report for $20 would that not be the easiest way?
Not sure about the easiest way, but it is $25 for a basic Blackstone oil analysis now.
It is not the same but it is used to perform the same test. The one in the video has 2 tubes, and this one has one tube.
If you are loaning it from Autozone, don't forget to loan the test fluid too, OEM/Block Tester Test Fluid (25739) | Block Tester | AutoZone.com.
) and you get your $36.12 back when you return the bottle and tester. In a nut shell, its a free test.
THANK YOU! ill be buying -renting- w/e a kit before i go look at an 80! the HG issue has me to scared to really pull the trigger on one maybe this will give me the kick i need.
Do not get wrapped up in HG Paranoia, just test the ones you are looking at (bubble test, milky cap/dipstick, Napa block test). I got mine with out testing anything and got lucky. But having said that I had money set a side to do a full PM maintenance and tune up as well as HG if needed. It also helps if you can do all your own work witch with an 80 series is a good thing to have.
and a half at best
i can do some but imand a half at best
HG is above my comfort level....
i keep going back and forth i read alot saying they WILL fail at 200k i read that its no big deal just vent under the hood keep the temps down and itll last forever
some peopel say drive it till it blows some say do it before...
if its not one thing its another i guess...
In the checks mentioned above, can someone explain what to look for in the bubble test? Are you looking for actual bubbles in the coolant or oil? I'm assuming that with the milky cap/dipstick check you are just looking for milky white residue on the oil cap and/or dipstick. Please correct me if I'm wrong on that.just test the ones you are looking at (bubble test, milky cap/dipstick, Napa block test).
