How to Service Diffs for Maintenance Section
Sachse, Texas
I didn't see a " How to Service Diff's" in the maintenance section. So thought I would make one for us " newbies" out there. Being a rookie to all of this I had to search other forums to find the info I needed.
Feel free to delete if this is repetitive.
1. Loosen the top " fill " plug first. ( Picture 1 ). Located at the top of the diff. This is so you don't drain all of your fluids out first and then run into possibly have issues getting the fill plug loose and being stuck w/o transportation.
2. Loosen the lower drain plug ( picture 2 ).
3. You can put a jack on blocks and jack up each side to help drain all the fluid out. This was recommended on another forum I read however after draining the fluids - I jacked up one side and did not have any additional fluids drain on mine. So this would be entirely up to you.
4. Clean off and re-insert drain plug.
5. Fill diff using gear fluids recommended in FSM. ( I chose mobile1 for mine ). Fill until it starts to flow out of the fill hole. FYI - this is best done with a oil pump connected to the bottle or a long flex hosed funnel. Both available at local parts store for <$5.
6. Drive vehicle in figure 8's to distribute gear oil.
7. Don't forget to recycle your used oil!
Hope this is helpful for the fellow rookies!
