How to replace front calipers and brakes on a 92
semlin said:
a certain parts guy believes otherwise but I'm ready to see him proven wrong
https://forum.ih8mud.com/showthread.php?t=16969&highlight=knuckle+housing
My experience is that they will bolt straight on no mods required. Maybe USDM is different? (mine is JDM)
Looking at the JDM EPC there are different part numbers for the housing knuckles for up to 93 and then from 93 on, I don't know what is different but the mounting points for the calipers are the same.
I don't have pics of the calipers together only the two different rotors.
the pn# difference for the knuckle housing might be due to the ABS sensor hole.
Sam can you list the PN#s for the calipers and rotors you took off and for the ones you put on?
Dan, if you are reading this, does the 93/94 poverty model without ABS have the same calipers and rotor as the abs version? If so, does the PN# match the 91-92 knuckle housing?
