I have a '82 FJ40 with a dragging rear brake drum - probably blown a wheel cylinder as well as having a leaking diff. oil seal.
I've been trying to pull the drum, but I'm having no joy with the shoe adjuster nut - what's the secret with these things - you cant see what your doing and there is a tiny hole within which you are supposed to juggle two screwdrivers - yeah right - is there a magic tip for this? Is there some other method I should be using - e.g. heat??
Regards
Justin
Regards
Justin
