How to remove centre dash "Oil Maintenance Required"
Westchester, NY
I don't know if the center console Other, Maintenance calendar is linked to the steering wheel dash display, but just around the time of my manually set reminder, the dash showed "oil maintenance required". I cleared/deleted the calendars on the touch screen, but the little dash display is still there.
  1. With vehicle ignition switched to ON position, make sure odometer is showing “Tripmeter A”, then turn the ignition switch to OFF position
  2. Push and hold the TRIP reset or MODE button
  3. While holding reset button, switch ignition to ON position
    **w/ ENGINE START/STOP button, keep your foot off brake pedal and push ENGINE START/STOP button twice to get Key On/ Engine Off mode
  4. Continue to hold the reset button until the odometer displays “000000” and then the original value is displayed
  5. Turn the vehicle off and back on to confirm reset was accepted
