How to power everything!
aaronrules
Coolest person you know!
Greenwood, AR
Okay so I am getting my ducks in a row for the 100's n the Hills in Aug. I will be needing to power a CB (probably this one: http://www.amazon.com/Midland-75-822-Channel-CB-Way-Radio/dp/B00000K2YR/?tag=ihco-20 ), iPhone charger, iPad charger and an Edgestar fridge freezer. I am not going to be able to a dual battery set-up before the trip. Will I be able to run all these accessories of the stock cigarette lighters? My iPhone is running through the stereo being charged that way. Just wondering if I can get the other three to run effectively. And hopefully without draining my battery.
Run them straight to the battery or put in an auxiliary fuse block. You do NOT want to run either a radio or a fridge through the cig lighter, the radio will pick up RF interference and the fridge needs more amps than the cig lighter can safely provide.
I've been researching options because I want to move my fridge between two or three different vehicles and my pop-up trailer.
The battery in a box idea works because all I need to do is run a heavy wire with an Anderson plug and fab a tie down. Probably $50 worth of wire, relay and breaker for each vehicle.
