You can change out to new flexy springs lime OME, or you can work with what you have. What I did to my Rancho springs made all the difference in the world. Remove your springs, take the individual leaves apart, blast off all the rust, take a grinder to clean up the edges, repaint with some DURABLE paint, line them with adhesive backed teflon, and reassemble, making sure to leave the spring clamps relatively loose so the spring is able to slip and twist. Get new bushings, and grease them up really well. Total cost is around $50 for the teflon, $15 on paint and the price of the bushings depends on the size of course. While I'm sure there are a few other tricks out there, my ultra-stiff rancho springs went from almost no flex front or rear, to very soft. Just to see, I borrowed my dads forklift, and was able to lift any tire over 33" before lifting another tire off the ground, the fronts were a few inches more. I also chose to remove the bottom spring on mine, and worked out nicely, but that may not work out for you. Best of luck to you.
