how to do compression check
i tried finding some info for compression check, there is no titles with such search at all, a little bit surprising? i did compression check on a supra and few other cars i had, but was hoping someone can refresh my memory.
engine has to be warm, disconnect some injector plug? then crank about 10 times per cylinder, but i dont recall what to unplug if anything needs to be on the 80?
Maybe this will help.
Compression Pressure:
Minimum [1] 883 kPa (128 psi)
Standard [1] 1,176 kPa (171 psi) or more)
Pressure Difference: Between Each Cylinder 98 kPa (14 psi) or less) [1] @ 250 rpm
Looks like yer right in spec.
thanks Gordo, with 130k miles is it normal to have such good numbers? or are most toyotas like this as long as they are taken care of?
They are well built engines.
