Good afternoon! I have searched here and online and have not found anything on this. Even had two other people look at it and can’t figure it out. I have put a Tundra master cylinder on my 1973 FJ40 for my disc brakes. It has a plunger type warning light switch in the cap, not a pressure switch like the OEM. Is there any way to wire it to the existing master cylinder? Or is there a way to bypass? As of now when I step on the break the warning light illuminate. I believe this is because it is not sensing any pressure in my master cylinder. The only wire that I have connected in the engine is a green wire to ground. Thank you for your time.
