how much would you pay for this????
City that rhymes with fun
whats a good price for a 77 4spd with Xcase, in decent condition???? i found one and the guy wants offers..... and how hard is it to put it in a 67 with a 3 spd on the floor????? much thanks
Been covered to death out here...
Flywheel housing is different, you will need a four speed version...
Hydraulic clutch set up is on the passenger side, and not the drivers like your three speed is, so this will need to be addressed...
Driveshafts are different lenghts....modify yours or get 4spd versions, and then mix and match your old ones with the new ones, or change companion flanges on the diffs, as the four speed versions use a larger ujoint, and bolt circle...
Tube crossmember is going to be really tight, make sure your parking brake works before you put the whole assembly in, as you will not be able to drop the drum off the tcase, without lowering the whole assembly...
Speedo cable
Parking brake cable
Shifter holes in the floor
Price?
500.00us or less would be fair....depending on the shipping side of things too...
People involved with the transaction, the location of the parts, and the demand for them will all play into this....there is no real set price for things other than what is published by some vendors out there...and that is for their products only...not necessarily what something is really worth...
Good luck!
-Steve
1-300 bucks depending on condition.
to put it in your cruiser you will need:
i think clutch and flywheel.i konw you will need the hydraulic line that converts it to the other side,and maybe the bracket that holds the slave cyl.4spd clutch fork and i cant remember the rest.sorry.good luck with it.its an easy conv if you know what youre getting into.mine was a pain in da ass cause i had no clue.but its worth it.but dont junk junk the 3 spd case use it behind the 4psd for lower gears.3spd case wont bolt up to the trans but you can make it happen
thanks alot steve, seems like alot of extra work, ill probly pass on it now.
If you intend on wheeling your truck a 465 tranny swap would make a lot more sense...
you can read about them and what needs to be done to make it happen in the many articles here...
http://www.ih8mud.com/cruisertech.php
Here is a really good write up on the topic: (just insert your stock case in place of the Orion :) )
http://www.root45.com/SM465Orion/
Good luck!
-Steve
i was going to do that too. but i found that the top gear is 1 to 1 on both tranys . I think everyone thinks a 4 speed means overdrive... but... it i guess the only difference is reducing rpm in second on the three speed.
Steve did a good job of explaining the process.... Thanks! i didn't know it was so complicated.
