238k miles and it smokes at start-ups sometimes. looks like it might be burning some oil. it also appears to be leaking maybe around the rear main.
also sounds like some valve chatter.
is it time for a rebuild and what's it gonna cost me?
can anyone recommend a shop in central ky that i could trust to do the job?
why rebuild it at this point? I would just go ahead and run the engine into the ground, then rebuild / replace. Also, you could probably find a decently good used 3FE for less than rebuilding one.
well, it is not currently my DD but may soon become so. I dont want to end up stranded with a blown engine. If I plan for the rebuild I can save money and do it on my time line, not in a rush.
Anybody have a low mileage 3FE they want to part with very cheaply?
It's 17 years old. A little smoke at startup is nothing to worry about. That's where most of your oil goes between changes.
Unless it's leaving a puddle every time you park, ignore the weeping at the rear main.
The valve clatter just means it needs the valves adjusted.
It's a 3FE. Slow. And practically immortal.
Honestly, if I had a 3FE, I wouldn't even think about a rebuild until 500k miles, unless there was a real issue needing to be addressed.
I prolly won't even touch my 1Fz-FE until then, unless the HG decides to go.
that sounds very high, it should be quick and easy job. It took me less than an hour last time I did it, including driving around to warm up the engine and I am not an experienced mechanic by any means.
Hell yes it sounds unreasonable. You can do this yourself. It's thoroughly documented online. The procedure is in the FSM. It's an hour or two if it's your first time turning wrenches. And you'll gain valuable appreciation for how simple it is to maintain an 80.
The smoke at start-up may be worn valve guides letting the oil drip by when the engine is stopped. Fix is to remove the head and get the valves redone. Not simple, but not impossible either if you're careful and take your time. But, if it's just a little smoke, don't bother. Ned
If the smoke bothers you, send the head out and get it redone. As stated, it's likely the valve seals. That's about $250 or so if you pull the head yourself.
Setting the valves will not do anything for the smoke, but it's probably due if you've never done it. $460 is NUTS. At most, outside estimate at the Toyota dealer maybe 2 hours of shop time. So maybe $220 would be a high estimate. It's been my experience that when shops quote a simple job for that much, it means they don't want to do it.
Do it yourself for free and learn something. You will probably need a new valve cover gasket, and PCV valve/grommet/hose.
The rear main is a big $$ job, but honestly it's far more likely to be your oil pan gasket. They always leak at high miles. It isn't a difficult fix, but it is a dirty one. I would do that before I even thought about the rear main. To do the rear main you need to take out the transmission which is why it's so expensive. The part itself is about $40.
I was just going to ask this forum about rebuilding my 3FE, looks like you beat me to it!
I have the same noises you have, a little oil leaking between changes, but I take these guys' word for it when I hear about the legendary longevity of the 3FE. I am going to get a FSM and do the valves though, it gets annoying.
