How much the does the wheel base shrink...
The Sunshine State
With a 6 inch lift. I am having slight problems fitting the long wheel base of the 80 under my 60 series. If the wheel bases is shortened at least .5 inches on each end it will help a great deal. This is not using the whole kit. I am using the stock arms flipped and a cut n turn for caster issues.... I am not using the slee arms. So, I guess this would just apply to the guys running a 6inch lift with stock control arms.
thanks,
-Al:beer:
A squared + B squared = C squared. Assuming a horizontal arm at stock height, then C squared is the stock arm length on the lifted application, A squared is the lift, and B squared is the effective horizontal length of the lifted arm.
So if the stock arm is 30" and the lift is 6", then 36+ B squared = 900.
B = 29.4
So 30 - 29.4 = .6" wheelbase shortening. 30" is an example...you need to use the exact measurements. However, .5" sounds about right.
Nay
Keep in mind that with wheels stuffed, the wheelbase returns to normal or worse. If the tire don't fit without springs, it ain't gonna fit flexed on a trail.
-Spike
-Spike
It'll never return to normal if it's bump stopped.
-Spike
that doesnt make much sense...essssplain?
if it is at a certain height un-flexed at normal ride height, it would seem to me that the wheel base would grow under compression. The control arm would move upward forcing the axle forward. riighhtt??
You're saying the same thing a different way I think. I think Spike is saying that it's a shorter wheelbase when it's lifted and sitting still, but then goes back to the normal wheelbase as it compresses - and moves forward. I read you both as saying the same thing.
The one thing though is you'll have lowered bump stops keeping the arm from coming up as far. I don't know if it ever goes beyond horizontal, and starts coming back again stock or lifted. Mine probably does with the drop brackets.
Sorta like the dwg... if you start level, you go up and back and down and back. If you start with the radius arm at an angle, you go up and forward and down and back - assuming of course, that when you go up (compress) you're not going beyond horizontal.
