how many amp fuse for two hellas?
Max, I just realized this is you, it is Drew from Rising Sun. Most of those Hellas come with a relay and harness, do you have all that?
Rezarf <><
Easy to figure out - add the wattages of the two bulbs. divide by 12, use next larger fuse.
example - (remember that amps x volts = watts, so amps = watts/volts) 2 x 100 watt bulbs = 200 watts total power. Divide by 12 volts (assuming common US electrical system) means your current (amps) = 16.66 amps, so, if you have 2 100 watt bulbs, you would use a 20 or 25 amp fuse. Substitute your own total wattage to determine your amp draw for these particular lights.
HTH, Blake
