I have three questions I could use a little input on. Oh yea, I did "search" and I can't even remember what I used as key words and the next thread I find is "Who shaves their nuts". I read the first page laughing my ass off. I will return tomorrow to read that and hopefully get some input on this;
1. I woud like someone to take a couple of readings for me of their rig using a volt/amp meter. If you would disconnect your negative terminal, hook the meter between the negative terminal and the negative battery connection and give me an amp reading, then take one connection loose and wait like 30 seconds then make a connection and tell me what the spike reading is? I have a constant .28 amp draw, but I spike close to 11 amps when I wait the 30 seconds.
2. Random misfire, only under load could be caused by plug wires?
3. I have a odd noise, when I am turning left I get a sound like something hitting under the shifter or near the gas pedal. I have looked under there and don't see anything loose, any ideas what that could be?
Thanks,
Yomama
Thanks,
Yomama
once it was charged, it would hold its juice till you turned on the stereo/amp. Is that thing drawing amps ALL the time? I will disconnect that tonight for sure. I need to rewire some of my stuff so it has a centralization and I can disconnect all the toys with one switch or relay it to the ignition ON!! Guess I know how my weekend will be spent.
