2badfjs 10 Year 15 Year 20 Year Joined Jan 26, 2005 Threads 298 Messages 4,871 Location in the garage Dec 6, 2006 #1 this is what i came up with. ended up not gusseting the axle (already have to much to do) maybe later the hole is centered. will make a strap later out of tie down material.
Mace rock scientist.. Staff member s-Moderator Moderator 10 Year 15 Year 20 Year OG Joined Feb 17, 2002 Threads 439 Messages 21,708 Location Las Vegas Dec 6, 2006 #2 Should work just fine. There is nothing special about a center strap piece. My upper mounted to the old shock mount on the frame.. Haven't bent it yet...
RVBtruck 10 Year 15 Year Joined Jun 19, 2006 Threads 9 Messages 210 Location Neenah, WI Dec 6, 2006 #3 looks like that will do her, it doesn't take much.
woody Adulting: do not recommend Staff member Admin 20 Year 10 Year 15 Year OG Joined Jan 15, 2002 Threads 548 Messages 10,380 Location SW Utah Dec 6, 2006 #4 outta work, unless you are jumping it a lot
RVBtruck 10 Year 15 Year Joined Jun 19, 2006 Threads 9 Messages 210 Location Neenah, WI Dec 8, 2006 #5 If you're jumping a lot one should run a pair. (And use some stronger stuff)
