- Joined
- Dec 24, 2003
- Threads
- 136
- Messages
- 3,559
Fine folks, I'd like to learn your thoughts on this please, when I replaced my radiator with the Ron Davis Racing variant I never put foam tape for the front face of the radiator on. With the rear face of the radiator the fan shroud sits super tight up against almost all of the radiator so I'm not really worried at all about that area in general, but, for the front face there is a good 1/2" opening that would theoretically allow air swirling all around the engine bay to get into the radiator. On the one hand that would seem to reduce the cooling capacity but on the other hand there are simply sooo many openings from the front cross-clip of the body that I cannot see how sealing the radiator to that one edge would possibly prevent all that air in the engine bay from flowing through the backside of the headlights and all the openings all around that front cross-clip anyway IF the air was so inclined ( I think that it was well established that the hotter high pressure zones whether moving or at stand still were towards the back of the engine bay).
To add some additional info to my question, when I received the radiator I noticed right away that there was no foam tape for it in the box and I called to RDR to ask them about that. One of their technicians told me that they try to avoid installing it cause the tape just eventually disintigrates, it is hard to really seal just to the outside air, and the capacity of the radiator is much more than enough to effectively deal with whatever small increase in air temps are towards the front of any engine bay. I asked if that applied when wheeling where speeds are slow at tops and he told me yes, less so than at top speed of course, but still so enough not to worry with the tape there. Made perfect sense so I installed without it. Its not that I'm questioning the guidance he gave but I'd just like to learn the thoughts of people who are much more familiar with our rigs in particular. I'm sure some of you have had your foam from your radiators let loose at some point and did you notice a measurable increase in temps, OR, after adding the foam tape back did you notice a measurable decrease in temps? Also, I've asked LX_TREME about his air diverter panel which should help some with preventing the air in the engine bay from flowing over the radiator support and into the radiator and SHOULD also help some with force feeding more air through the radiator instead of through all those openings all over the cross-clip. Anyways, thanks so much as always for your thoughts.
