How hard to replace tranny?
Vancouver, WA (NOT B.C.)
My buddy has a '94 FJ80 Automatic tranny that went out. We are wondering how hard it would be to replace it ourselves rather than pay Toyota $1100.
Any feedback would be great. Thanks in advance.
well not to hard just bolt on bold off kinda thing but there bluddy heavey.
u will need to get the transfer case off the box and there a 2 section transfer case so in order to unbolt it from the box u need to pull it appart.
if u have and engine crane u can go in through the car or 2 traolly jacks u can do it.
hope it helps
With a automotive lift and the right tools not a bad job maybe 1/2 day. On your back in a driveway with only jack stands and a floor jack" (PRICELESS)", possible but would not attempt. I own a Lexus/Toyota Speciality shop and would never attempt to do this job without a lift and proper tools. A shop would charge approx. 6.5 to 8.0 hrs labor at say $85.00 an hour. Without lift and tools, well worth the money.
Well, when you got a meth addiction and are into Cruisers, you got ta do what'cha got ta do to feed the twitch!!!
:flipoff2:
Cruiser Jimmy has the right method for us without a lift equiped shop. I would just note that using a ratchet strap over the top of the tranny adapter works wayy better than the chain it comes with. Also mounting a 4x4 block of wood on the front or rear of the jack gives better surface area vs. just the metal edges of the adapter since the tranny doesn't fit down inbetween it on the flat area.
It can be done. I even did it in a single width apt. garage. I had to tilt the cruiser sideways to get the bellhousing to clear the sliders when pulling it out since it ws still attached to the tranny jack. That was fun.... Having the right jack is the key. Don't skimp on a good tranny jack. It makes all the difference. I actually also used a second floor jack to assist in the reinstall. I did this by myself.
Yeap, me too. But when age starts to become an issue, it starts to hurt.
Now, in keeping with the MUD standard, I'm surprised that someone has not devised a way to use a wench and block and tackle the line into the sun roof down through the center console whole and lift up the tranny.:hillbilly::hhmm:
I used a tranny jack from a shop that works on semi's.
It was the right size for the job.
I used the small tranny jack adapter like the one shown and it is a bitch to use on just the t-case.
I would not attempt it on the tranny even without the t-case but I did the job alone.
One thing to watch for is the wires to the O2 sensors, I pinched them when installing the tranny at the bell housing.
I ended up dropping the tranny three times and lost count on how many times I dropped the t-case. I had pawned the tranny jack adapter and would rent a tranny jack if I had to drop the tranny or t-case if I had to do it one more time.
