How does the brake vacuum reservoir work precisely???
On the road
In an earlier thread I asked about this thingie and it turned out to be a vacuum reservoir for the brake booster.
So today I took out the reservoir to see what the problem is, because the PO had taken it out of the brake system. But the problem is that I only can open it with a slash hammer, so no possibility to see what's inside.
Does anybody know if there's a membrane inside? When I blow in the input pipe, the air comes out via the whole for the sensor, and also out of the output hose. But when I blow in the output hose, the thing is closed, so I presume there's some kind of one way valve in it.
So does anybody know what's inside?
Can't say whats inside but it probably isn't more than what you found so far, a tank with a check valve to make sure it holds some extra vacuum when need exceeds supply.
Probably works somewhat in the same way as a battery. Most of the time the vac pump supplies sufficient amounts of vac for the brakes on our diesels but the tank takes over when needed until the pump catches up.
I noticed the other day when I changed the brake master I pulled the vac hose off the booster and there was still vacuum on the hose and the rig had sat overnight so I guess I can say there are no leaks in my booster or vac resevoir.
Tony
Tony
Yeah, maybe I just have to connect it and see what it does. Wouldn't surprise me if the PO just disconneted it because of a leaking hose.
Kynot pretty much summed it up, however they put the canister in there so that if your engine quits you have enough reserve vacuum for a stop or two.
Thanx for the info:)
