How do you replace the ignition switch? 94 model
I have had enough issues with my ignition switch that I bought a new one from Toyota, as well as having a new key made from the VIN while there. I need to get the new ignition switch keyed to the original new key. Once that's done, I'll be ready to pull the old one and put the new one in.
I've got the FSM, big thick book for the 94, found how to test it but nothing on how to remove it. Have been looking here using the search function as well as all over the net and even Youtube but have yet to read anything on how to do it. I found tons of these questions with all the tips to prevent having to change it. I don't need any more, "Try this first" tips. I've bought it and am going forward. Now I just need help in how to get it out.
Please tell me that there is an easy way to gain access to it without having to pull the entire dash from top to bottom to gain access to it. Does the bottom section of dash come off somehow so I can unplug it and then turn it to accessory and push the hidden pin section and it slides right out? I just can't figure out how to get the bottom of the dash off without having to remove entire assembly.
If that's the only way...so be it but I am thinking that there has to be an easy access of this part somehow.
Thanks in advance.
Figured somebody would have replied but this surprises me. Does this mean that nobody here has done this before that can give me some help?
When I used to dismantle Toyotas this is what I did when we sold ignition cylinders:
1. Disconnect the battery (not sure if its necessary).
2. Make sure you have access to the ignition cylinder. There is a little metal button you have to depress to pull out the lock cylinder.
3. Put key in ignition and turn to "unlock".
4. At the same time, depress button and pull the cylinder out by pulling on the key.
If you need the ignition switch, I believe there are 2-3 little screws on the back of the lock cylinder. It should have a rectangular plug and pigtail off the back of the switch. Unplug the harness and remove screws from back.
I've never looked at the back of an 80 so not sure how easy it is to access the screws holding the ignition switch to the lock.
Hope this helps.
