How do you remove this?
Anchorage, AK
I am trying to remove the front output shaft out of a HF2A. I removed the C-clip thing from the gear that in on the output shaft, but I can't remove the gear that I'm sure needs to come off and put back on the new front output shaft. Do you have to press out the front output shaft from the housing? Can you do that with this gear still in place and remove it later? Please see the picture and the gear that the red arrow is pointing at. Thanks.
There was another thread in the last week or so. The OP gave a full write-up with pics and he described how he removed that gear and the "tool" he cobbled together to remove it.
Searching is always the best way to get information. If you cannot find that thread then let me know and I will be happy to look for it and post a link for you.
Later.... Here is the thread started on 9/23/2008: https://forum.ih8mud.com/80-series-tech/242281-nobody-has-seen-seal-i-have-seen.html
-B-
I found it by using Advanced Search, 80-Section, posts only, Keywords=transfer, gear
It was the first thread that was returned by the search. I also remembered that there was a recent thread (~7 days).
I will agree that searching is not getting any easier because of the large amount of posts that are in the 80-Section. Success using the SEARCH function just means you have to get more creative. You can always ask someone to give you help with search terms or author. I am always willing to help when requested.
-B-
I used a modified steering wheel puller: I cut the ends off, threaded them and used ready rod to get the length I needed. The neon straps shown in the pics serve only to hold everything in place while I snugged it all up and made sure I was pulling straight.
Thanks, I will try the search again.
Search for what? I gave you the pointer to the thread and knorrena is the OP. There's nothing else to search for coldtaco.
-B-
Aww, be nice Beowulf - computers and links are still a conondrum for some. Me included sometimes.
Geeze, and I thought I was being nice.
And it is conundrum. :flipoff2:
-B-
