How do I remove the brake booster? RTH
Minnesota
I've got everything removed, but I can seem to pull the booster out of the engine bay. There isn't enough room, by the time the bolts clear the holes, the engine is in the way. Any tips here?
I just did this resently. It comes out easily - once you get the angle just right. I assume you've already detached it on the inside, right?
I tried to remove it without messing with the master cylinder and couldn't. So I ended up loosening the nuts on several of the hard brake lines so that I could rotate the master cylinder and some of lines out of the way without stressing them too much. It's easy to do and and I didn't loose too much brake fluid. Once the lines were rotated out of the way, the booster came out easily. I think it was a twisting, upward motion toward the DS fender direction. Good luck.
Thanks, worked like a charm. I pulled extra hard and cut my hand on something, but it's a small price to pay. I read some posts about people lifting the engine or the intake manifold. Wow.
