How do I remove an 84 Toyota PU A/C compressor?
Is the system already evacuated?
If not, you will probably need to bleed the system.
You basically pull the hoses, loosen the tensioners on all of the belts and pull them off, remove the clutch connector, pull out the 4 bolts that hold the bracket to the block.
What about just leaving it in and removing the belt? Or leave it in and turn it into an air compressor.
