How do I grease my birfields?
Spicewood, Texas
Pulled the birfs and installed an Aussie. My Haynes manual does not cover greasing on reassembly. I pulled the axles and cleaned every thing. Do I just pack the knuckles best I can, or do I attempt to fill it from the square plug on the top/front of the knuckle? They are CV axle-shafts on a 76 FJ40.
Thanks,
Jeff :confused:
Pack as much grease as you can inside the bell of the birfield till grease start popping out. Personally I don't put a lot of grease in the actual knuckle because of potentially breaking a birfield tho I do have longfields. Just put some grease around the knuckle and on the outside the bell of the birf and you should be good. The birfield is supposed to be floating inside the knuckle anyways not rubbing it.
