For Sale Houston, Tx - LX450 Headlights
Houston, Tx
  1. LX450
I have a set of takeoff headlights from my 1997 LX450. All tabs and mounting locations on both are fully intact and undamaged. The driver side is almost pristine, the only blemish is a small slightly "burnt" spot that's slightly brown above where one of the bulbs goes in. Its barely noticeable even when your looking for it. The passenger side is cracked and chipped with a small hole going all the way through. Lower trim pieces were painted black but the paint could be stripped. Buyer will need to source the upper trim pieces as I am using them in my swap, upper and lower are still available new i believe.
EDIT: I thought I was using the upper trim pieces in my swap but realized I am not. They are unpainted factory chrome and will be included
$400 OBO, will consider trades
Will ship at buyers expense
Hello,
Do the adjusting gears work properly?
I will check on this for you tomorrow morning. I would Imagine they most likely do as the car they were on is clean and rust free but I have never messed with them.
Hello,
All adjustments look to be working fine. The big screw adjustments are a little tight but working.
BUMP! Open to offers!
