Hot air is always diffusing into the cabin
Lebanon
Dears,
A hot air is being transmitted to the cabin inside while its turned to the AC and it's off.
Please help and advise what to check .
Assuming this is an 80, year would help. Does the heater control valve under the hood on the firewall react to a change in the cool/heat control? Meaning does the valve open and shut when you slide/rotate the temp control?
Never mind - realized I was in the 80 section, not the 40 section. :oops:
Would you please check the attachment, apparently it was replaced and seems there's no stopper for hot water , right ?
Yes, someone bypassed your heater control valve, so you have hot coolant going through your heater cores all the time. You need a new heater control valve and install it.
If you have a rear heater, this may affect that as well.
After you do that, you may need to check your vent doors to make sure they are operating when you change the selection.
Shouldn't exist valves to switch between the heat and the cold water? I saw something inside the car above the ECU, AREN'T these valves for this purpose ?
There is only hot water and the FLOW is either on or off. If someone bypassed your heater valve on the firewall, you have hot water going through the heater core all the time. Any air drawn into the cabin will be heated, even if you have the AC on.
When you move the temperature selector to blue (cold) it closes the heater valve if the heater valve was in proper operation.
If you have the AC on, it will cool down the incoming air, but the heater will heat it back up and give you lukewarm, DRY air.
I have totally removed my heater control valve and do not have hot air coming through my dash vents when the slider is over in the BLUE....just sayin'.
But still, replace that control valve and see what happens.
FYI - you need a new engine air intake hose too...:)
Hence the reason to check the vent doors as well, to make sure they are actuating.
He is also having AC problems, based on another thread.
I am guessing there are some serious HVAC issues here. I am not familiar with Lebanon to know if it is arid or tropical or what, but that may give an idea what to look for and what will corrode or get plugged with debris.
I guess you clot the pipes so the hot water cannot enter the cabin anymore.
Yes indeed, I have changed the hose intake air but this image is befire
Nope: I have HOT coolant behind my dash at all times, no hot air through the vents until I want it hot.
The vent doors in my truck are working correctly, so I cannot tell the hot coolant is back there.
My thoughts: if you have HOT air at all times, the vent doors in the heater box behind your dash are probibaly malfunctioning.
