Hot AC relay
Surprise, AZ
Question up front: what might cause the latching signal terminals on the AC relay to get hot on a 91?
Backstory:
Bought the truck without AC (missing compressor) and recently completed rebuilding the system and converting to r134a. Of the final issues, the fan blower wasn't working on max, and threads here pointed me to the relay. When I pulled it (OE), I noticed the above burnt terminal, but the relay terminals and housing looked fine. I tested it and it felt soft in regards to latching, but wasn't showing continuity when switched anyway. I swapped a relay from another circuit and the fan worked fine on max.
I bought another relay (off-brand, gasp!). The system worked for about 30 mins then popped the 30A fusible link. I pulled the relay and noticed that the housing had melted. The melting caused the internal latching contact to shift and short on another tab, so that's what was blowing the FL.
I took apart the OE relay, tested/cleaned the contacts, and it's functional again.
Given that the PO did not complete the AC system, I'm not sure if it was a cost issue (converting to r134a) or some other gremlin that he just gave up on chasing. Because the relay block is burnt but the OE relay shows no sign of fatigue, I presume the relay was a replacement when the system wasn't functional, or was some part of another troubleshooting process. Still, it's hot enough to melt a new relay, even if generic.
What's causing it to get so hot in the first place? Should I just stick with the OE relay, or also try to clean out or replace the contacts on the relay block? I'm thinking maybe they charred over enough to reduce contact area and increase resistance. Suggestions?
