horn relay
College Station, Texas
Is there a horn relay on a '77 fj40? I noticed on a '78 the horn power appears to be coming out of the fan cooling box. I replaced the horn buttons on my steering wheel and still can't get the horns to work. The PO had the horns wired directly to a horn button under the column. I figured he did this because the horn buttons in the wheel were broke. Any help would be appreciated. Matt
Better test the horns too. Both of my horns were bad when I bought the thing. Just touch it to the battery. I did exactly what you did, could not believe both horns would not be working. Replaced one with a min truck one and went on.
Tested both horns. They work fine. Turns out, the relay is missing. The plug is there but no relay. I suppose when the contacts broke the horns blew constantly. The PO removed the relay and wired them up manually. I'll get a relay. Thanks guys. Matt
