Horn hookup OEM hareness
Lafayette, CO
my new to me 7740 doesn't have any horns, nor a horn relay. my question is, where do horns plug into the OEM hrness?
The headlight hookups each have one dangling connector (blue or green I think). IS this where they should hook up?
thanks
The horn wiring comes out of the headlight loom on both sides (driver and passenger) as a Green/White wire. The right side (high horn side) also has a White/Black ground wire coming out of the loom(although the ground is not specifically for the horn).
The horn relay has three wires, G/Y, G/R, and G/W. I think its located on the firewall on the right side.
For the relay G/R is power in, G/Y is from the horn switch, and G/W goes to the horns.
Hope this helps.
Thanks!
that's exactly what I needed to know. thanks again.
Happy Cruising.
