Horn connector
New Jersey
Anyone have this happen? What was your solution?
If you read my previous post (prior to this edit) - pls ignore. I didn't notice the connector itself had come apart.
Usually those connectors have pins that can be pushed out using a small needle or awl. Then you'd need to reconnect the wires and re-insert the pins. I think those connectors are just a simple spade on the horn, so you also could get some spade "socket" connectors and just use those instead of the factory connector.
