Homemade Sliders
Nashville, TN
Has anyone made, or thought of making sliders out of galvanized water pipe. I have access to this and it is pretty thick and strong. Im thinking the 1" or 1 1/4"
Are you welding or using threaded pipe?
Holy sheet I saw a dirt track race car built out of nothing but threaded pipe for sale about a year ago. Wow.
Back to the sliders. Get the trail gear or marlin pre bent, pre welded dom or hrew, whatever it is. Use the pipe you have for a sprinkler system. I like you thinking like Fred Sanford though. Would make my Gramps proud.;)
I have welded a lot of galvanized metal. My aunt Lucy thinks that I am a bit loopy! My mind is not affected at all! Zink is my friend! I love the smell of zink in the morning!
But seriously, you can weld on zinc coated metal without problems and with proper ventilation. The ventilation needed will usually disrupt the welding if you have enough airflow to remove the poisons, but you can work around that if you need to. I have built roof racks from galvanized EMT conduit. It is strong and reliable. It is also light in weight. But it requires special welding conditions.
The problem is that most water or gas pipe is not nearly as strong as mild steel tubing. It welds well because it is soft. It looks good because it is thick. It is also very brittle. It cracks easily. To a newby it seems to work easily. But to have a strong steel welded structure, flexibility is key. Whether it is a roll cage or a chassis, it must have some flex. Cast pipe cannot flex. It looks strong, but it is not. It cracks easily. It only works in places where it is well supported.
Metal has a grain just as wood has. Mild steel has a long straight grain, like pine or oak. Chrome-moly tubing is similar, but more similar to walnut. Plumbing pipe is more like cork. Brass is similar. They are all very brittle and prone to cracking. I limit those materials to places where a single hit will destroy them, such as bumpers. There, they perform OK. They are OK for blunt-force impact, but not for structural material. You do not want your car to be built out of gas pipe!
heckler;[URL="c2c://14082647207" said:
2647207][/URL]i would not use galvanized, because it will make you sick if you weld with it. Just use some good old schd40 pipe.
if you google welding with galvanized, it is no worse for you than non galvanized.
i would weld them not use the threaded and connectors.
as for the cracking on impact, i dont plan on crashing them on rocks, i really dont do any of that type of offroading, its more of off pavement. The main use would be for the kids a little help getting in.
