Holley Fuel Regulator ?
San Antonio TX
Still fighting this damned fuel issue. I believe I've got it now narrowed to the fuel pump being the issue. I replaced the old electric pump with a new Holley Blue pump and regulator. It was set at 8# so I tried to reduce it to about 6# which is about optimal for a Edelbrock carb. The problem is, the regulator will not drop below 7#. This pressure continues to blow fuel from the needle valves etc. WTH is going on with this thing? I rebuilt my edelbrock and then replaced it with another operating carb and it responds the same way.
I'm out of ideas.
Anyone?
Thx
I have used a Carter 6 psi street pump with a Holley standard fuel pressure regulator to cut back to 4psi. Our Edelbrock also would not take higher fuel pressures.
I'm surprised your regulator won't let you go below 7#; the ones I've used all will. I work in an industrial enviornment, and we check gauges routinely. You might be surprised at the errors we find. So try another gauge, or find someone with a test gauge to check yours against. Like Brandon says, even 5-6 psi may be too much for an off-roader with an Edelbrock carb.
Have everything plumbed in and fired up the 40 ran good for abt 30 seconds then back to pushing fuel through carb orifices WTH is going on 2 carbs, new pump etc and still have same problem
The Holley Blue Pump is a high volume, high pressure pump for race applications. Even at 6 psi, we pulled our Edelbrock off three times to check and lower floats. Dropping below 4 psi solved the flooding problem. You might try a Facet 2-4 psi electric pump. Most auto parts have them.
