Holley carb offroad mods
Once when we were wheeling this guy with a Holley in his pickup couldn't get back up the hill - it was loose and rough and his engine kept flooding out. I took a piece of surgical rubber from a wrist-brace type slingshot and ran it from vent to vent with a small hole in the top, just cleared the top of the air cleaner. Worked like a charm, no more flooding. I have no idea how long the tubing lasted, but I do know that trick works. That is my only experience with Holley carburetors.
probably not cheap but holley makes an off road carb already set up and someone makes a kit for those.think there was an article in one of the wheeler mags with an article on how to mod them for off road use.im not a holley fan so i didnt keep track but help is out there good luck
x2 on not wasting your time with that Holley POS.
Been there - done that - don't waste your time.
Even if you do make your Holley run as good as a TA Holley you haven't accomplished much. The Holley TA carb is still worthless for the extreme stuff.
Even the link you posted mentioned that it worked for him but he didn't do extreme...
Quadra-jet for V8s - Aisin for Fs....
What about the holley truck avenger series?
I though that they were supposed to be good offroad.
Really? I have a Q-jet now and was thinking of going Holley TA.
Is this a bad idea?
Why is the Q-jet so much better?
Q-jet has a different float bowl system that is very hard to flood out. I have been so sideways 3 guys were hanging on the side to kep me from tipping and gas was flowing out the gas cap. I always said the day my Q-jet doesn.t work for me is the day Ill put in fuel injection. Hasnt happened yet.
First, if I had a manifold that took a Q-jet, I'd want that carb. I've only had them on V8's, and been tickled pink.
Second, If you looked on our website you'd see that we not only baffle and chimney the floatbowl, but we have a kit to "seal" the baffle. That is the trick, and those who have baffled, but not sealed the baffle may have been disappointed in extreme use. Those who did seal the baffle were happy young bucks. I'll elaborate in a PM if you like.
Well I guess I will be keeping my Q-jet!
I had the 2barrel holley on my 40. Ran pretty good on the street, ran like hell on the highway. Sucked ass off road. I once was stalled on a samll rocky outcrop in the middle of a wet meadow for 45 minutes. No way around it, everytime I strated up it, it would bounce and stall out. Just couldn't get it to burn all that extra fuel at 11,000 feet.
Mileage was not optimal either. Continually had a flat spot on acceleration, never could tune it out. I jetted and rejetted, tried countless powervalves. Had to install the powervalve saver also, as I kept blowing them out due to lean run and backfire when cold due to open air cleaner and such.
I tired the whistle deal, kind of helped. I extended the breather, kind of helped. Found a junkyard 4 barrel and put the side hung float on in place of the center hung float. Helped alot more. Even went so far as to take a junkyard metering block, drill and jet the holes on the side of the power valve area, where fuel is let in, as a Holley actually puts out too much fuel for a stock F. Did the spring loaded needle and seat, also helped some I guess.
Then I realized, after years of trial and error and little results, that I was trying to build a Holley into an Aisan, and I bought an old worn out stock carb, clenaed it, repaired some stuff and stuck it on. Never been happier and that thing will damn near run upside down, never floods out, bounces, all that crap that my Holley was famous for.
I think I just need to do a rebuild on my Q-jet. Its running rich as hell.
I have a Q-Jet on the V8 in my 40. It is desperately in need of a rebuild. However everyone I talk to around here says it is better and cheaper to buy a new carb versus rebuilding a Q-Jet.
Thoughts?
I dont see how buying a new carb can be cheaper than a rebuild.
A big problem with the q-jets that costs some money is getting the throttle plates re-bushed. I got a rebuilt one off of eBay that ran with the pig flat on it's side. Cost me $40 still sealed in the plastic. It was a great carb. Adjusting the secondaries just right to eliminate the transition bog is something a lot of people don't do either. Not really a big deal on an off road rig.
I just took it off to do a TBI. I was having a bit of a problem with sensitive throttle response in low/low/1st. I also wanted the easy cold start of the TBI.
If Holleys make you go fast, then I have the fastest dumpster in the midwest outside of my shop.
fastest dumpster.......... thats funny.
