Holley 2280 carb
A friend of mine is trying to install this Holley 2280 carb onto their cruiser. They bought a rebuilt kit for it, but can't find any info on setting the new float? How do you know where to set that little metal tab that your supposed to bend? In the photo, that brass threaded fitting is the fuel line shut-off that the flaot taps against and shuts the fuel off or on. Does anyone have specs on settin the flaot to the right height?
You might check Holley's webpage for info. They have quite a few carb manuals and specs available online there.
Of course most folks here will tell you that Holley carbs work best when they're on the bottom of the trash can or tossed as far into the weeds as you can throw one. :D
Good luck with it...
Nick
I tossed mine, (actualy put it on the old GM C60), much better application IMO. the asian works better in off camber situations and seems to be a little more fuel friendly, little less acceleration though.
Downeyoff-road also sells a spring loaded needle and seat valve in case you wanted an improvement over the stock set-up. You can also find this wear any holly products are sold.
I've been running the Downey Holly conversion for years and it seems to do me ok.
