HJZ80 Headlight Relay
NSW, Australia
I have had my '95 Ozzie HJZ80 for about 7 years. When I bought it, the previous owner had replaced the headlight bulbs with higher powered halogen bulbs. It makes the lights much more powerful. The Ozzie HZJs have twin rectangular lights. I think that the std low beam is usually 55/60W and the high beam 55W, but my replacements are 55/100 and 100W.
Soon after I bought it, I had a terrifying experience - 100km/hr on a two lane highway - truck approaching - dropped back from high beam to low beam - and the headlights went out - completely. No lights. I survived that ok, getting stopped on the edge of the road in the dark.
I found the headlight relay was so hot that the plastic cover had melted. I rewired it and got going, and simply replaced the relay and wiring and used it ever since. No problem. Up till last week. Same problem again!
I bought an OEM relay, and it only worked for less than an hour. So I have pulled apart the dodgy Toyota relay, cleaned the contacts and bent one pole so that the gap is closer, and I am using that again.
My question is this - is 400W of high beam too much? (I also have a pair or 130W spot lights but they are relayed up separately). Has anyone else had a similar problem? Should I go back to std bulbs, or relay up the high beam?
try your local ARB they will have a upgrade for the harness
ARB have a harness? Sounds like this is a well known problem. I thought that there would be more responses to this topic if that was the case.
If it is a know problem, then is it necessary to replace the harness (or even part of the harness), or would it be just as effective and cheaper to wire up the high beam to run off another relay, in the same way as the spotties?
You cant use the standard wiring and relays with upgraded headlights, thats why most people replace the harnesses.
I have made my own HD loom and relay box, which contains 1 relay for low, 1 relay for outer high, 1 relay for inner high, 1 relay for spotties and 1 relay for roof lights :grinpimp:
PS. i havent upgraded my headlights, but with the new circuit, you dont need to anyway.
Is it 12 volt? If so, you are looking at >33 amps draw. Most standard automotive relays that I have dealt with are only rated for 30 amp continuous use. The stock draw (assuming 12V) is ~20 amps so the factory relay is probably rated for ~25 amps.
Yes, 400W is definitely a lot for the standard relay and for the charging system in general. It can be also bad for the headlights. Headlights that have plastic parts could melt with so much heat.
The Australian 80s have sealed-beams (no plastic bling!). The only issue is the stock harness.
