HJ61 Spring Distance Plate
Australia
Hi Guys,
My Landcruiser leans to the drivers side by an inch (Right hand side in Australia)
From my understanding distance plates can be used to correct this. Would you guys know on which side this needs to be installed and where it goes?
Cheers
That's a band-aid that won't fix the problem. The low spring is weaker than the higher one and will continue to distort further. The best solution is to replace both springs if you can afford it. It's going to need to be done eventually.
Anyway - the springs are mounted under the axle. Installing a spacer under one of them won't lift the vehicle, It would only drop one side.
