hi fellas just picked up my 2nd 60 series cruiser a few months ago 88 HJ61 VX 24volt import pretty impressed the 12HT is soooo much better than the dirty old 3F carby in my other FJ62
anyways been slowly doing work to it to get it ready for Roadworthy cert, the times come to sort the charging system electrics arent my strong point i've had a bit of a look through some previous posts but cant quite find the info im lookin for. heres the issue my battery/filter/turbo lights ect flicker on and off from idle to about 1700 or so RPM then go away, my voltage guage in the dash doesnt show any volts at all ever, where does the guage get it reading from? the voltage regulator on the alternator? im not the best with auto electrics especially 24v use to the normal 12v stuff, my first step will likely be to try replace the brushes, any help appreciated
, anyway i picked it up thisarv along with a multi meter and some contact cleaner so ill see if i can have a bit of a poke around with the multi meter, i found this info here on HJ61 charging systems:
