HJ60 engine upgrade
Montrose , Victoria ,Australia
G'day , new to this site , I have a HJ60 fully set up for outback touring , I need to upgrade the engine to a turbo diesel and retire the old under powered 2H, ideally to a 12HT would be the best suited but having trouble finding one , does anyone know what is involved in updating to a later model ?1HD FTE ? and where to get the associated bits?
thanks , Mal (Victoria,Australia)
Check out watrob's conversion posts in the diesel tech section:
https://forum.ih8mud.com/index.php?threads/12HT-into-a-40,-all-finished..820973/
There are a few others looking into and doing it at the moment but all said and done you're chasing a $3k to $7k motor to put in a vehicle that came factory with the 12ht in it.
I know it sounds like a good idea now but you should really really really consider getting a HJ61 or TD 80 series because I can guarantee you'll be spending North of $5k even in the backyard not to mention the headaches.
Good luck with the hunt the 12ht motor is one of the best but rare as rocking horse sh1t
DIY rebuild to turbo spec you may be in the vicinity of $2k all said and done then a reputable turbo kit like the high mount garret from turbo glide is around $3k so same net result really.
You can always do it the red neck way and find a bolt on unit from a wreck or something for around $1k then turbo it and rebuild later. Either way you will be in for a rebuild at some stage.
The path I trod with my 60's was extractors and snorkel with a good tune and accept the fact she'll be slow up hills but will last a million kms and wait for the right 61 to come along.
Others will tell you different about turbo but I'm a purist these days.
yeah I do agree with you there crick, my main problem is the 4 speed box in mine travelling over 90km feels like you are revving the engine to hard getting to that speed i have no problem with.
32" or 33" tyres will help you out a little but you'd have to go 10.5 wide max. Turbo won't help you with the 4 speed, she'll still rev her tits off.
LOL yeah i just went the 33s seemed to help a little was thinking changing diff ratios a little could help as well might leave me stuffed at the lower end but i dont think so.
