Hello all.
I am currently trying to diagnose a noise my HJ47 troopy has had for a while.
With the clutch pedal out and revs under 1500 i get a crunchy rattle from the transmission. With the clutch in and/or revs above 1500 the noise goes away. If I roll along in 1st gear the noise still only comes about when the clutch is engaged.
I initially thought it was a clutch release bearing giving me troubles but wouldn't that make noise under load? i.e. when the pedal was in and the clutch plate was getting pushed. Not when the clutch is engaged and the pedal is above the friction point.
My other idea is that it is the input bearing of the gearbox as this would be under load when the clutch is engaged but would not neccesarily make noise when the gearbox isn't being loaded from the enigne?
The gearbox and transer functions fine, its a 4 speed split case.
I'm going on a 4000km drive with a full troopload and trailer in September, so i really need to get this fixed.
I'm going to drop the box out next week but i've never done this before.
Any help would be much appreciated.
