Hi all,
I need to remove the utility box that a PO hacked into the passenger side of the troopy. Does anyone have any recommendations on where to get an appropriate replacement panel? I suppose I could get some 14g flat steel and use the opposite side to make a template. I have a plasma cutter but that might warp the panel. I'm not concerned with the rolled lip of the wheel opening because I plan to run flares.
Any other good solutions you guys could recommend?
Thanks
Randy
Thanks
Randy
