Hitch Question!!
Calgary Alberta Canada
When I imported my cruiser from Japan it never came with a hitch.. now I will be needing one. I do have the OME 2.5 Lift on the rig, and want to keep the back end as high as possible for wheeling (minimal).
As I have seen there are a few choices..
Factory take off
Reese
Pintle
Etc.
What would you recommend??
Thanks,
All will hang down some. Valley Industries made the OEM aftermarket hitch in the states, but I don't think they make it any longer. You may be able to find one for sale in the For Sale section on this board. I sold mine a couple of years ago for about $75 IIRC.
If you've still got a factory rear bumper, the hitch will provide you protection and warning that you're draging your arse!
EDIT - Kaymar is another option for a rear bumper with a rated hitch built in.
The best one for highest clearence is to go with either the 4x4 labs rear bumper or slee bumper with add on hitch.
Also, a very expensive route to take, either way.
One question that needs to be asked is what will you be towing?
That may help determine how "beefy" of a hitch you need. I have the Slee rear bumper with hitch/receiver add on and haved towed a 3500# popup camper. It worked fine except that the hitch receiver hole that you slide the ball mount into seems a little too big, allowing the ball mount a little to much movement (banging) for my preference.
If you don't like the loss of clearance you can do what some have done and mod the rear cross member to install the hitch higher, or even what Nay has done. IIRC he bought just the Slee receiver and installed it with the stock bumper. Note the Slee receiver requires that you cut a hole (square) in the factory rear cross member piece. I believe Nay has a thread on MUD showing his install.
:cheers:
Don't forget the Drawtite option. It makes a good compromise if you're still going to have the spare hanging under there anyway. It isn't a plow blade like the US port installed hitches.
https://forum.ih8mud.com/showthread.php?t=104627&highlight=drawtite+red
The install was easy. Be sure to soak the tow hook bolts in PB Blaster or similar a day or two before you start.
You may need some bolts: M12x1.25 grade 8.8 or better. I just ordered mine from McMaster-Carr.
In addition to all the hitch related stuff above, you should check out what you have on your JDM LC with regard to towing package. In the states, all LC's were brought in with the towing package as standard. I'm not entirely sure what this entailed, but it was at least the tranny cooler. Depending upon what you are towing, you may need/want to install one if you don't already have it there.
Just installed the pintle hitch in the rear frame and it looks nice. I'm very happy with the install, but if you don't have a trailer with a pintle hitch it won't do you much good! The bolts for the top holes are a little hard to find, but Fastenal has them in zinc plated (m12-1.25 60mm).
Thanks guys.. I bought a factory take off that was just sand blasted and freshly powder coated for $150
Thanks again,
