Hitch Pin Mod
pensacola florida
i am doing the hitch pin mod and had a question, every post Ive seen this mod mentioned and depicted people only put a hitch pin on one control arm...why wouldnt you put on on both arms?
Excuse my ignorance, I was just curious
If you pulled both bolts, the axle would spin on itself, destroying your steering, panhard mounts, driveshaft, brake lines, etc.
-Spike
OK that makes since, im glad I asked first, thanks
Flex and measure carefully, with stock arms and caster correction there can be interference between the arm and tie rod. When flexed so the side without the bolt is drooped, the arm is allowed to swing up more than normal, possibly contacting, bending the tie rod. Whether it works or not depends on the amount of droop (shock length), amount of caster correction, etc.
and which caster correction method...
