Hilux front hub conversion
Queensland, Australia
Hi Guys, am looking to widen the track on my "85 75 Series , have heard that it can be done with some later model hilux bits, just wondering what are the components that I need? I do have brake and hub bits from a '92 VZN 130 hilux V6 (rotor 291 diam x 25mm thick), these don't mount up, what do I need?
thanks for the reply, looks like I have the right parts, assume the hub spacer sets the rotor back around the 20mm needed for the caliper to line up with the bolt face, does that mean that the rotor no longer sits in the machined surface that usually supports it?, will look for one online, is Marks adapters the only one who has them?. Had a quick look, nothing shows up on Marks site.
seen that, bit expensive, seen how you can also mount to the other side of the thread boss and eliminate the need for the spacer, will have a look and see how things fit, thanks.
