Highway vibrations
Minneapolis, MN
Hello everyone,
I took my 80 up north about 5 hours this weekend on all 55+mph highways and noticed some strange vibrations. When I got the truck up to around 70+mph, I was getting an intermittant vibration; below 70mph the truck felt more than solid. It would get stronger, and then fade away, but seemed to come back again. The truck was loaded down with lots of skiing equipment, but I don't think weight played much of a factor. I was initially thinking u-joints because I had vibrations that led to a snapped joint on my 90 4Runner at highway speeds, but the 4Runner seemed to shake much more violently. The truck drives straight down the road, and there isn't much shaking of the steering wheel other than the entire vibration of the truck. I know this can't be too good, and would like to get it taken care of. O yeah, I just recently purchased the truck, so I have no idea when the joints were replaced last, but most likely never (180xxx miles). Should I just go ahead and put new u-joints in, or should I look somewhere else first? Thanks,
-TT
I'm chasing the same kind of vibe. I hink it's the pinion bearing in the front diff. I say this because as the truck gets warmed up at 70 MPH, after about 15 min. of driving this intermitant vibe, and growl begins. The longer I drive the worse it will get, until it's a constant sustained groan. Then it stays like that for the trip. I just got finished driving 600 miles in 24 hrs, with temps in the teens for the most part. Seems less noisy than on warmer days. Took about 30 min. of driving to hear it.
I'm rebuilding the front axle with C-Dans kit, plus wheel bearings, and new pinion bearing. I'm also having the d-shafts rebuilt and balanced. I'll let you know the results in a couple of weeks.
That's exactly the symptoms that brother Brian's had with a bad pinion bearing, his was a rear.
Thanks tool. Did he have any seapage from the pinion seal? Mine is dry as can be. I was hoping this trip would make it bad enough to rear it's ugly head. I'll check in the morning to see if there are any changes under there.
This ol' truck just plugged along all day today at 70 MPH with a strong sustained head-wind, and 30 max down to about 10 degrees tonight. Once again this truck with 180,000 miles on it just amazes me. The Mighty 3FE...I love it!
Thanks.
Thanks.
I think his seal was good too? He lives about 90 miles away and makes the trip often. In town it was quiet, when warm on the highway it would growl somewhat like a bad wheel bearing. He did a burf/front bearing repack, no help, repacked the rear bearings, no help. When he drained the rear diff fluid there was a small amount of gray filings on the magnet, so we started there.
Pulled the diff, everything looked and felt good, pulled the carrier, it looked good. Spinning the pinion by hand with the carrier out the growl was evident. Ordered the pinion bearings, crush collar and seal from Kurt at Cruiser Outfitters, ~$60. Nice parts and a big thanks to Kurt for the tech help! Set them up with 10 in lb of preload, reinstalled and no more issue.
I seem to have the same problem. My cruiser is still stock (unfortunately), and around 74 mph can hear a repetitve roaring growling noise, not really a vibration but can kind of feel in floorboard. Ordered pinoin and carrier bearings from Toyota right next door to me and am still waiting on carrier bearings. So I picked up rear u-joints from Napa in the meantime and am just waiting on the time to install. I hopefully will put them in tonight or tomorrow. I might just pay a tech $20 and let them do it. The noise is bad enough where I don't want to drive it on the hwy at all!:doh:
I also have the gurgling vibration rattle when I let off the gas at around 45mph too. Hoping u-joints will take care of it. My t-case sounded quiet while it was running in the air and I only have 94k on her so I hope its ok. And yes I did grease them all several weeks ago and they feel tight but I figure they are 10 yrs old anyway so no harm.
Just web guessing, that sounds like u-joints, can you feel the vibration in the transfer shifter? Have you inspected the u-joints, do they have play?
No significant play felt at all and can feel a slight vibration in t-case shifter. Hoping thats all it is since all my bearings and seals are almost $300 from toyota.
I'm also wandering if it might be tire related. The seller put 2 different types of tires front and rear. The size is the same and the tread is almost identical in wear but I know that different tire manufactures can make tires slightly different true sizes. Any input there from anyone?
I think my vibration might be slightly different, since I'm not hearing any strange noises, just vibrations. Did you notice the vibrations before the growling became evident? If so, I could be having the same issue, just not as far along. Let me know how yours turns out. I think I will just go ahead and replace the u-joints as PM, since I have seen the damage a broken one will do at high speeds :doh:
-TT
I just took ownership mid Nov and haven't noticed any vibes before, but the noise has been there since the first time I took it on the hwy. I do have a slight vibration when turning and when truck is shifting into 2nd which is kind of odd. On a non related issue my 80 doesn't shift into o/d until warmed up a little and or going 60 mph or more but shifts great otherwise, any input there, normal condition of an 80, and the fluid is good and red and full.
Come to think of it, my 80 likes to run high on the RPMs when its cold too. I never really gave it much thought. I just thought it was to warm up the cold engine, but that could be a different issue. I have never gotten mine up to overdrive speeds with the cold engine, because by the time I get to the freeway, the temp gauge is not tanked out anymore. Maybe someone with some more experience could chime in on this one
