Highway driving help
So guys i found a couple of 3rd members from an fj60. I understand from what i read that i will need new pinion flanges. Can i take them of the 4.11s i have or should i get new ones?
I have 3.70s from a FJ60 in my Dec/78 build FJ40. I currently have 30" M/Ts but will get 31" A/Ts at the next tire change. I can cruise at 65-70 comfortably. I've hit 80 but the acceleration between 70 and 80 is pretty slow. Not sure if I had I could have eeked out a few more miles. One tip - the FJ60 gears front/back are the same. Typically there will be more wear on the back b/c more use in RWD. Install the FJ60 front gears in the FJ40 rear and vice-versa when you do the swap. (I have fine spline already - not sure if you'll have to do anything else.)
Hey, I went through all this. Kurt at CruserOutfitters fixed me up with everything I needed. Very knowledgeable.
You'll want the pinion flange and new crush nuts for installing the new flange. It isn't rocket science to do the job, but just pay attention to the details. Did mine more than 15K miles ago and all is good.
Call them. They can answer all the questions and get the correct parts in your hands.
Cruiser Outfitters
The pinion flanges are here-
Cruiser Outfitters
I bought my FJ60 differentials from cruiseryard.com but would never do business with them again. They sent two diffs with different ratios and would not make things right.
And was pleased with their product.
Your pops will like the 3.73's and 31's still plenty peppy with a bit longer legs
I ran 3.73 and 32" tires for years. Loved the combo..
I plan on using the thirds out of my 79 FJ40 along with 32"/33" tires in my 65 FJ45 pickup. Besides the higher gearing the longer wheel base should be close to a 60 Series as far a s ride. Going with a late model H42 and split transfer case to complete the drive train.
Great info here.... I'm tossing around the idea for my '71 fj40. I have 33s and 411s good for off-road but it does start to rev at around 55mph. I'm good at 50.... And as soon as 55-60 comes, just seems to be too many rpms. I've even had it up to 75 but she was screaming. So, just looking at getting the revs down, even if it's just slightly.
I've tossed around the idea of looking for a Fairy or Ranger (can't find one), an H55, or now I've learned that 60 series 3rds will drop in for a little more highway friendly 373. Thoughts/suggestions?
At 65 you are at 2700rpm (ish)
60 = 2500
55 = 2300
50 = 2100
If you go to a 3.73 gearset
65 = 2500
60 = 2300
55 = 2100
50 = 1900
You are talking about a 200 rpm reduction. Also, 2700 rpm is not even close to being too much for a 2F motor (if it is indeed a 2F).
If you have a diesel, then the numbers are correct but the rpm range is different obviously.
33's and 4:10's are a good combo, 60 mph all day long
Thanks for the numerical data Mace! It is an F w/ 3 on the tree! Does this data equate to 29/30 inch tires? I wonder if that 200 rpms is worth it... Especially sacrificing when I'm off-road?
LP, I can do 60 all day. But, it is noticeable between 55 and 60.
Thanks for your feedback!
Easy peasy calculator..
Engine RPM Calculator
29 in tires, 60 mph and 4.10 gearing gets you 2857 rpm at 60.
New pinion flanges is the "hard way" IMHO. The driveshaft u-joints are the same size on a '77 FJ40 and FJ60's. Swap the diff ends of the drive shafts to match the pinion flanges of the new diffs. WAY easier than swapping pinion flanges and worrying about pinion bearing preload and pinion seals.
Nick
Best thing is to find other ways to get places that don't use highways/freeways. Might take longer but the views are better and it's a lot more enjoyable because the back roads better suit the truck.
