Higher Idle with AC on
Folsom, CA
My 91 3FE at typical idle is about 600-700rpm, i think this is low, but that's what it is. When I kick on the AC the idle jumps to 800-1000rpm. Anyone have this issue before or can help point me in the right direction? FSM is on its way, but slow in arriving.
That's normal. The A/C system kicks up the idle whenever the compressor's engaged. Further, if you're using your A/C and it's not super-hot out, your idle should cycle up and down every few minutes or so as the compressor engages/disengages.
Oh, and idle spec on a 3FE with engine warm, tranny in park, and A/C off is 650rpm.
Curtis
yes, it's 650 rpm on the 1FZ too without AC per FSM, and mine goes to 800 or so with the A/C on. All that with a warm engine of course.
