Highbeam issue
Scottsdale Arizona
Hi,
When I go from low to highbeam sometimes it will work but most of the time it wont. if I work it back and forth it will come on again. how can I clean up the switch? do I need to take the steering wheel off? I am sure all other contacts are good. its no fun to drive in the dark on windy roads:mad: with deer:eek:
thanks
I'd start with some contact cleaner. You should be able to find it at Radio Shack.
Do I need to take the wheel off? It sounds like no to start with........... just fire it down the turn signal shaft eh? I'll give it a go..
on the early piggies, pre 9/'72 ish, you do need to take the wheel off. also, you will need a paper clip to remove the plastic connector shell from the wires to totally remove the switch...otherwise its trapped by the column sleeve. you will see what I mean once you try to remove it...
clean the s*** out of it with contact cleaner from an autoparts store, or radio shack. use a fine W/D sand paper or steel wool and get the oxidation off the contacts. What turned out to be more of my problem than the contacts was the cam that moves back and forth. it hung up on some crusty ass grease.
Use some white lithium grease and lube it up and install...
ok....thanks bunches!!!!
Good thread, I have the same problem but have not gotten around to looking into it. Now it will be easy, thanks!
:cheers:
