High Low gear knob vibrating
Rochester kent UK
Is it normal for the Hi/Low gear shift to vibrate when driving normaly on the highway, it depends on the speed, say 45pmh is worse rhan at 60mph? not noticed it before.
There should be no noticeable difference between speeds. Actual vibration should be nil.
Yeah I think so cause mine does the same thing. It vibrates more the faster you go. Also when I accelerate it moves over to the right. Its really wierd.
Well if you think so, then it must be so........ :flipoff2:
Is it fully engaged i.e. have you shoved the knob as far as it can go. You have just striped and greased your shaft recently, did you mark it up so that the splines on the sliding shaft line up as they were before as they are balanced, I remember that you were complaining recently of noise associated with the transfer box. :eek:
mmmmmm Yes I did remove the shafts, and it seems like the vibe has started since then, but I did mark the splines and the flanges, I was thinking that I had not noticed the vibe b4 cos I have not had the car very long
It is possible as you become more familiar with driving it that you will notice the odd thing or two. Vibration from a prop can be an imbalance usually through miss alignment of the sliding shafts which you have ruled out or a shot UJ which often causes a growling or droning noise and can even sound like a blown exhaust I have had many of them on Landover’s so am used to the sound. An other problem can be caused over packing of the sliding splines but have never experienced this, but do know it can cause a lot of damage.
OF COURSE IT IS reffug DUH!!!!!
I think have the same vibration in my 93. Mine is only present during acceleration and if IIRC it was there before I installed the J springs.
my 96 does the same thing with the vibration I think it is normal? but i would like to know for sure as well!
I have wondered that before as well and oddly tonight reached down and felt it while driving, mine vibrates a little, think it is normal.....
The transfer case shift knob on my 94 vibrated.
The transfer case shift knob on my 80 vibrates.
The transfer case shift knob on my wife's 80 vibrates.
I vote "this is normal"
It's really noticable if you have a set of keys sitting on the boot touching the knob or the shaft.
If your lever move a great deal, another place to look is the motor mounts, and the transmission mounts. Some vibration is ok, but lots of movement is not (back and forth say 1/2 or more, not to say less than a 1/2 is good either). Most of my movement is vibratinos with slight movement upon accleration, maybe less than a 1/4 inch. later robbie
man, I'm impressed...
I was expecting a deluge of jokes on these posts, and only one so far...
You guys are really getting mature! :D
well I looked at my knob today and on acceleration it does move a bit to the right, and twitches as well, well I hope it does not start to leak! a leaking knob can be dissasterous.
concretejungle said:
e9999, i think there were plenty of subtle inuendos within this thread........shall we continue?
subtle??? I don't think so....
