High idle
dnp
Supporting Vendor
Jackson, MS
I did a search, and most of the issues I found were concerning a low idle. Furthermore, I had posted this question in a multiple-issue post before, but since it's continuing, I thought I'd ask again.
OK: post-1fz rebuild and head gasket replacement, I have been experiencing a high idle condition. It works normally at first (will idle high from cold start up, but when it lowers after a small amount of time, it never gets down in the range I understand to be "normal.") It'll idle down to about 1,000 or so, but very rarely will get in the 650-750 range, but most of the time it's higher. Some here had suggested before that it just takes a little time for the ECU to "relearn" where it's supposed to be. However, after a few weeks of driving it, the ECU is still dumb where idle is concerned. Symptoms are: usual idle in the 1,000 to 1,200 range, with a kick-up in A/C-on RPM to the 1,600 range.......When trying to keep the windows defogged (A/C on) and in low range, there's some pretty firm brake pedal pressure going on in trying to fight forward motion.
Does this issue ring a bell with anyone who may have cured a problem like this? Thanks.
try resetting the ecu.
Happened to me once, after doing some work on the engine. Was idling high for a couple days.
I jusgtdisconnected the battery for a night, next day after it warmed up it was idling fine.
HTH
Ryan
Sorry to revive such an old thread, but I have never been able to correct the problem I stated in the first post. If I crank it up and don't drive it - just let it sit there and idle - it'll usually idle down to where it should be (in the 650-700 range) However, if I drive it at all, it idles high the whole time I'm driving it (in neutral, 1,100 when the a/c compressor is off and 1,400 when the a/c compressor is on). Throttle body is clean, all cables are slack (proven by the fact that it sometimes idles correctly), etc........at either range, it idles smoothly, so I don't think my EGR 401 code is causing it, so do any of you have any ideas on why in the world this truck won't idle down? Thanks
That doesn't sound like much proof to me.
Problem could easily be sticking cables. Next time it's idling too high, pop the hood and try closing the throttle by hand. If you can lower the idle at all, you've got a problem somewhere in the linkage.
Curtis
check how tight the throttle cable is on the throttle body. There should be just a little play in the cable.
If you can slow the idle down by closing the throttle by hand or lifting up on the accelerator pedal, it may be the cable is binding. Might try spraying some lube into the engine side. My was acting similar and it seems to have fixed it temporarily.
