High compression and one odd plug?? (dial up users beware)
Vidor, TX
Here are some pics of the new 80. It's amazingly clean under the hood, hard to really tell how clean in the pics, but I was impressed.
When I did a compression test, it came up really high. 188-185 except #4 was about 177 and the #4 plug looks a little different. It's also throwing the infamous EGR Flow Insufficient code. My guess is that the EGR is screwed up and it's causing some serious carbon build up. Any other ideas? Any ideas on a solution other than pulling the head? Here are the pics:
The #4 plug is the far right.
A close up of #4.
Random engine bay pic.
Another random engine bay pic.
Yet another random engine bay pic.
It's a tight fit in the garage, the passenger's door will only open about two inches.
Yes I am going to fix the rear end leak on my Cobra next month. It's getting 4.10 gears and an axle girdle.
And finally, the magic switch. I had the fuse cover off to run the scan the EGR code, it's not missing.
I gave fair warning to dial up users, so don't complain.
And, does anybody know of a good upholstery shop w/ fair prices in the Houston area?
I have begun my quest to solve the EGR problem. I pulled the sensor from the base of the EGR vavle. It was coated in carbon. I cleaned it up and reinstalled. Here are the before and after pics.
Sensor w/ tons of carbon.
Some more carbon.
The cleaned up sensor.
It cleaned up pretty good.
I'm headed to Autozone in the morning to rent a vacuum gauge to test the rest of the EGR system. Wish me luck.
Surely someone on here knows a little something about these engines. Has anyone else had high compression like this? Or am I the first? Comments? Suggestions?
The number four issue might be a leaking spark plug tube seal or some water got down in there. The tips looked to be the same all the way across so probably just a little moisture. More than likely not a big deal.
I can't comment on the compression, just be happy the numbers are quite level.
Quite often, cleaning the carbon won't solve the po401 problem but still a good thing to do. The vsv is one of the culprits.
Buck
I just put new spark plugs in. It's running good. Now I have to see if it will throw the P0401 again. The VSV is under the intake correct? Do they normally need to be replaced or cleaned? How much does a new one cost, ballpark?
Correct, vsv is under the upeper intake. Don't know the price off hand. CDan is the official parts guru and discount giver around here. He's one heck of a good guy as well ( a little butt kissing for the Shaman goes a long way :grinpimp:)
VSV or a new EGR is usually what it takes but could be a lot of things. Plugged vacum lines from carbon, dirty egr temp sensor which you've done, might need to clean the ports on the throttle body. All these things are good to do regardless but, it is just a process of ellimination.
Do some searching on po401 and you'll find tons of info. There is also a thread on our club forum.
Buck
Before you start changing expensive sensors, make sure you don't have any vacuum lines plugged, ask me how I know.. I changed vsv, changed the EGR Modulater to a new blue top, and still no fix.. I don't remember what exact vacuum line it was, but that was my problem...
those were some gaps on those plugs...
The compression looks good to me?:confused: Is your gauge precision calibrated, most aren't, I have seen them way off and depending on the method used readings can very. I interpret the reading by evenness across all cylinders more importantly than the actual reading, screw in new plugs and drive happy.:hillbilly:
Well, I have no idea how long those plugs were in there, but it looks like a long time considering how much it had shrunk. The guy I bought it from said he never changed them and he bought the truck with 90k on it, now it has 142k, so at a minimum of 50k.
